Yes, but only in the narrowest sense, and it's true of every VPN. Someone watching your connection can tell you're connected to a known NymVPN server. What they can't see is what you're doing, where it's going, or even whether a given packet is real.
What an observer can see
NymVPN's server IPs are public, like every VPN's server list. A passive observer, your ISP, a Wi-Fi operator, a network censor, sees only:
- That you're connected to a known NymVPN server IP.
- That the connection is encrypted.
- Roughly how much encrypted traffic flows in and out over time.
They can't decrypt the content, see the destination, or read what's inside.
What they can't see
- Your content, which tunneled encryption keeps from third parties and Nym alike.
- Your destination. In Fast mode no single server sees both your IP and where you're headed; in Anonymous mode the 5-hop mixnet makes even your traffic patterns unreadable.
- Real packets from noise. In Anonymous mode, cover traffic runs alongside the real thing, so decoys and activity are indistinguishable.
Hiding that you use NymVPN at all
On some networks, corporate, university, or in restrictive countries, connecting to a known VPN server is itself the problem. Two features help:
- QUIC transport mode disguises the connection as ordinary web traffic. See What is QUIC transport mode in NymVPN?
- AmneziaWG, the Fast-mode protocol, adds decoy packets to the WireGuard handshake to beat the deep-packet-inspection signatures that block plain WireGuard.
For restrictive regions, see How to use NymVPN in restricted regions or networks?
What about correlation attacks?
A powerful observer watching both your link to NymVPN and your traffic's destinations, a "global passive adversary", could try to correlate timing and volume. This is what defeats simple VPNs and Tor. Anonymous mode is built to resist it: cover traffic hides real patterns, packet mixing prevents per-user fingerprinting, and timing noise breaks the correlations the attack relies on. For everyday use Fast mode already beats a traditional VPN thanks to decentralization; reach for Anonymous mode when you need certainty that no one can tie your patterns to you.
Related questions
Can my ISP see I'm using NymVPN?
It can see you're connected to a NymVPN server IP, but nothing you do inside the tunnel. To hide even that, turn on QUIC transport mode.
Can a website tell I'm on NymVPN?
Some sites keep lists of VPN exit IPs and may flag them, which is true of VPNs in general. We're working on residential server options where it matters; see the public roadmap.
