服务器会影响到您的连接、网速、隐私程度以及能访问的内容。 NymVPN uses two connection points that you select independently: an Entry server (where your traffic enters the network) and an Exit server (where it reaches the open internet).
NymVPN uses two types of connection points: Entry and Exit servers.
入口网关:这是您连接的第一台服务器。 For the best performance, choose a nearby country or one known for strong data privacy laws, such as Switzerland or Iceland.
出口网关:这是负责将您的流量路由到互联网的服务器,它会替代您的真实 IP 地址,代表用户连接到网站或者服务。根据您的个人需要选择相应的国家的服务器(例如解锁仅限特定区域访问的内容或保护个人隐私)。
如何选择合适的国家
For privacy: Select Entry and Exit servers in countries with strong data protection laws. 例如瑞士、冰岛,或者那些提供强大的隐私保障的欧盟国家。
For streaming and geo-restricted content: Set your Exit server to the country where the content is available. 例如,选择美国作为出口服务器以访问那些只有美国可用的内容。
有些国家实施严格的网络审查,比如中国:中国政府部署了强大的长城防火墙,旨在限制 VPN 的使用以及阻止公民访问国外网站。 India has also expanded its internet censorship policies in recent years, which may affect your connection when using Indian exit servers.
For censorship resistance: Avoid Exit servers in countries with strict internet filtering such as China, Iran, or Russia. 这些国家可能会屏蔽或者影响您的连接。 If you are located in a censored region, connect your Entry server to the nearest unrestricted country.
For general browsing: Set the Entry server to your nearest available country for the best speed. Set the Exit server to any country without heavy internet regulation.
您可以查看文章“为什么连接到特定国家的服务器之后我的线上活动会受到审查?”以了解更多信息。
您也可以参考组织全球网络自由度监管的非盈利组织Freedom House提供的年度报告“Freedom on the Net”来了解更多信息。
