NymVPN 并不保证每次连接都会分配新的 IP 地址,但也绝不会将您绑定到固定的 IP 地址上。 Each connection routes through a randomly selected server from the pool in your chosen country or region. 有时你会获得一个新的 IP 地址,有时则是同一个。 Either way, your activity stays private because the network is decentralized and the server only sees encrypted traffic.
NymVPN 如何选择出口 IP 地址
When you connect, NymVPN selects an exit server from the available pool in your chosen country. 默认情况下,选择是随机的:
- If multiple servers are available in your chosen country, you'll could get a different one each time you reconnect.
- If only one server is available for that location, you'll get the same IP repeatedly until more servers come online.
- You can also choose a specific server manually using the country selector in the app, which gives you a stable IP for sessions where consistency matters (banking, certain logins, geo-restricted accounts).
You can see all available servers on the Mixnet Explorer.
你们为什么要这样设计
NymVPN 的隐私特性并不依赖于轮换 IP 地址。而是源于网络的去中心化架构:
- In Fast mode, no single server sees both your real IP and your destination, regardless of which exit server you land on.
- 在匿名模式下,五跳混合网络(mixnet)结合掩护流量与数据包混合机制,能够防止观察者将流量与您关联起来,即使出口IP保持不变。
这与传统 VPN 的工作方式不同。对于一般的 VPN 而言,出口 IP 是主要的隐私边界:一旦它发生泄漏,你的身份也就随之暴露。 NymVPN 的隐私特性植根于网络架构之中,而非依赖于 IP 地址的新鲜度。
关于地理定位的说明
The country shown to a website is inferred from the server IP by an IP geolocation database. 这些有时可能会不准确。请参阅文章为什么 IP 检测网站显示我位于一个和我在 NymVPN 选择不同的国家?
