Decentralized VPNs (dVPNs) like Orchid, Mysterium, and Sentinel fix the central-server problem that traditional VPNs share. NymVPN goes further: it's the only dVPN built on a Noise Generating Mixnet, with cryptographically unlinkable payments and metadata protection that simple multi-hop dVPNs can't match.
每一款去中心化 VPN 都做对的事情
All dVPNs swap centralized corporate servers for a distributed network of independent nodes, removing the single point of failure: no one company to hack, subpoena, or coerce. NymVPN, Orchid, Mysterium, and Sentinel all share that in some form. Here's where NymVPN pulls ahead.
A mixnet, not just multi-hop
Most dVPNs route through 2 or 3 independent hops. That removes server trust but not traffic analysis: an observer can still correlate packet timing and size to fingerprint users. Anonymous mode adds three things plain multi-hop lacks: packet mixing (your packets shuffled with other users' at each hop), cover traffic (decoys that mask real patterns), and timing obfuscation (random delays that break correlation). That's what makes NymVPN resistant to AI-powered surveillance, and no other dVPN offers it.
zk-nym 凭证:不可关联的匿名支付技术
Most dVPNs still tie your payment to your account somehow; even crypto leaves a record that can be traced back. NymVPN's zk-nym credentials prove you've paid without revealing who you are, so once your subscription becomes a zk-nym, your payment can't be linked to your sessions. See nym.com/zk-nyms.
Audited, and built on real research
NymVPN has been audited by JP Aumasson (2021), Oak Security (2022), Cryspen (2023-2025), and Cure53 (2024-2025), a track record rare among dVPNs, and the mixnet builds on a decade of academic research with leading European university teams. It's tested against the strongest threat models, not speculative.
快速对比
| 功能 | NymVPN | 常见的去中心化 VPN |
| 去中心化节点 | 是 | 是 |
| 多跳 | 两跳或五跳 | 常见多为两跳 |
| 混合网络/掩护流量 | 是(匿名模式) | 否 |
| 不可关联的匿名支付技术(zk-nyms) | 是 | 否 |
| 匿名注册 | 时(助记词) | 不一定 |
| 独立审计 | 多次(2021-2025年) | 不一定 |
The trade-off: Anonymous mode adds latency. For everyday browsing, Fast mode matches other dVPNs on speed while staying decentralized and log-free by design; reach for Anonymous mode when unlinkability matters more than throughput. More in the NymVPN litepaper.
