You can install NymVPN on Windows, macOS, Linux, Android, and iOS. One subscription covers up to 10 devices, all signed in with the same 24-word access code.
Step 1: Download the app
Download NymVPN for your device:
- Windows: nym.com/download/windows
- macOS: nym.com/download/macos
- Linux: nym.com/download/linux (see How to install NymVPN on any Linux distribution?)
- Android: nym.com/download/android
- iOS: nym.com/download/ios
Step 2: Create an account and subscribe
If you don't have an account yet, select Get NymVPN on nym.com, generate your 24-word access code, and choose a plan. Full steps: How do I create a NymVPN account?
⚠ Your 24-word access code is the only key to your account. It replaces email and password. Nym cannot see or recover it, so save it somewhere safe (a password manager secure note is easiest) and never share it. Nym Support will never ask for it.
Step 3: Install and sign in
Run the installer for your platform and follow the prompts. Open NymVPN and sign in with your 24-word access code: scan the QR code from your account dashboard, or enter the words manually.
Step 4: Connect
Choose a mode and connect. Use Fast mode for everyday browsing and streaming, or Anonymous mode for maximum privacy. 您也可以参阅文章快速模式和匿名模式之间有什么区别?
