NymVPN runs on Windows, macOS, Linux, Android (including GrapheneOS), and iOS. One subscription covers up to 10 of your devices simultaneously, signed in with the same 24-word access code. The current minimum versions are listed below.
Windows
- Windows 10
- Windows 11
Download from nym.com/download/windows.
macOS
- macOS 14 (Sonoma) and later1
Apple Silicon (M1, M2, M3, M4) and Intel Macs are both supported. Download from nym.com/download/macos.
Linux
- Debian / Ubuntu 22.04 and later (deb package or AppImage)
- Arch Linux (AUR)
- Flatpak (any distribution that supports Flathub)
- Universal installer script (Fedora and other distributions; client app and daemon installed together)
Linux uses two components: the nym-vpn-app client and the nym-vpnd daemon. The deb, Arch, and universal-installer paths set up both; the Flatpak and AppImage packages install only the client and require the daemon to be installed separately. Full install steps in How to install NymVPN on any Linux distribution?
iOS
- iOS 16 and later1
- iPad supported
Download from the App Store.
Android
- Android 7 and later
- GrapheneOS supported
- F-Droid available (see How to use F-Droid for NymVPN?)
Download from nym.com/download/android, or grab the APK directly from nym.com.
What about routers?
Router-level NymVPN support (OpenWRT, pfSense) is on the public roadmap but not yet available. The challenge is implementing router-level support without breaking the zk-nym credential rotation that makes the system anonymous. See Does NymVPN support OpenVPN or other protocols? for context and follow the public roadmap for updates.
A note on older macOS and iOS versions
Supporting operating systems that no longer receive security patches introduces risks for users and slows down development. We focus on versions that Apple actively maintains. Following Apple's end of security updates for macOS Ventura 13 in Q4 2025, we ended support for macOS Ventura in early January 2026. iOS follows the same principle.
Câu hỏi liên quan
How many devices can I use with one subscription?
Up to 10. See How many devices can I use with NymVPN?
Do I need to install a separate app per device?
Yes. Each device runs the NymVPN client app for that platform. You sign in on each device with the same 24-word access code.
Does NymVPN work in a virtual machine?
Yes. NymVPN can run inside a VM on a supported guest operating system. Note that running NymVPN on both the host and guest at the same time can create routing conflicts; choose one.
