When you pay for NymVPN, Nym uses zero-knowledge proofs to keep payments and usage unlinkable. NymVPN puede verificar que tiene una suscripción válida sin necesidad de saber quién es o conectar su pago a su actividad de navegación.
Your NymVPN account ID is a public-looking identifier that starts with n1. Es cómo se hace referencia a su cuenta NymVPN en el sistema, y puede ser útil cuando contacta con soporte.
Option 1: Find your NymVPN account ID on the NymVPN website
A) in the support section (account identifier)
Inicie sesión en el sitio web de NymVPN.
Open the Support section.
Look for Account identifier.
This value starts withn1and can be copied using the copy icon.
B) in the address/URL bar
Vaya a la página de inicio de sesión de NymVPN.
Log in with your 24-word access code.
Después de iniciar sesión, comprueba la barra de direcciones de tu navegador.
Your NymVPN account ID appears in the URL and starts withn1.
Option 2: Find your NymVPN account ID in the NymVPN app
A) open settings from the main screen
Open the NymVPN app and log in with your 24-word access code.
On the main screen, click the gear icon ⚙️ in the top-right to open Settings.
B) find the account ID in settings
In Settings, scroll to the bottom.
You’ll see Account ID (starts with
n1).
You may also see a Device ID underneath.
Note: On mobile operating systems (iOS and Android), the NymVPN account ID can be found under the "Account" option in the Settings menu.
What to send to support
If you’re asked for an identifier, send your:
Account ID / Account identifier (starts with
n1)
This is different from your 24-word access code, which acts as the key to unlocking your account. Do not share it when you request for support.
