To uninstall NymVPN on any Linux distribution, open the terminal and run the following command:
curl -fsSL https://raw.githubusercontent.com/nymtech/nym-vpn-client/refs/heads/develop/.pkg/linux/install | bash -s uninstall
This command downloads and executes the uninstallation script. It will remove NymVPN and its associated files from your system.
评论
0 条评论
请登录写评论。
