The NymVPN app is available for installation via F-Droid an alternative app store for Android. For full installation instructions, please visit this page.
Name | Description | Version |
NymVPN | The NymVPN client app for Android | v1.1.7 (11700) |
How to install NymVPN via the main F-Droid repo
- In the F-Droid app, search for "NymVPN" and follow the app install instructions or visit https://f-droid.org/en/packages/net.nymtech.nymvpn.
How to install NymVPN via our private F-Droid repo
In the app, navigate to Settings > Repositories and click the "+" floating action button.
To add the repository, click "SCAN QR CODE" and scan the QR code below, or add the repository manually with the following URL:
https://raw.githubusercontent.com/nymtech/fdroid/main/fdroid/repo?fingerprint=06C095C54BBFE147C986FD29ADF4E9BCD5E95ECACD6D865C6045B66B0B5500FB
4. You can now install Nym apps, e.g. start by searching for "NymVPN" in the F-Droid client.
Please note that some apps published here might contain Anti-Features. If you can't find an app by searching for it, you can go to settings and enable "Include anti-feature apps".
License
The license is for the files in this repository, except those in the F-droid directory. These files might be licensed differently; you can use an F-Droid client to get the details for each app.
Bình luận
0 bình luận
