NymVPN operates exit servers in multiple global locations to provide broad coverage. You can view the complete list of our exit servers by visiting the Nym Explorer.
What you'll find in the Explorer
Unlike a traditional VPN, the Nym network is made up of nodes run by independent operators around the world. The Explorer shows these nodes and their locations, giving you a live view of the decentralized network your traffic travels through.
Choosing locations in the app
You do not pick individual servers. In the app you select entry and exit countries, and NymVPN routes you through suitable servers automatically. For guidance, see Best NymVPN server location: how to choose entry and exit countries.
Câu hỏi liên quan
Why does the list change over time?
Independent operators join and leave the network, so the set of available servers evolves. That decentralization is a feature: no single company controls the infrastructure your traffic depends on.
A location shows the wrong country on IP checkers?
That is usually a geolocation database quirk, not a wrong server. See Why does an IP check show a different country than I selected?
